It is a LS block part number 1262-1766, Aluminum also marked 6.2, I think it is out of a caddy. I can not find any other info. Is it a good block for a build? Is it a LSA ? What is the difference between this block and part number 1262-1769 or part number 1262-3968 ? 1st LS build, I want to put a long crank in this block, with a twin screw on top, up to about 16 to 18 pounds of boost max, for a rear engine sand car. Any tips on mods I should do to this block. Thanks X
