Helmholtz Resonator tuning for a "high pitched" exhaust system.
8.6K views 11 replies 7 participants last post by  ForceFed86
After hearing corsa extreme exhaust systems in person and Looking at this video of one opened up. It appears they are just using the Helmholtz Resonator method but in reverse of its typical application. Looks to me like they are using a super short Helmholtz Resonator to cancel out the low frequencies, then using a hollow "tinny" chamber to amplify the high freq sound? Could be wrong... but they sound completely different than any other muffler I've heard.
I'd like to setup a DIY version of this... Was curious if the "Chamber" is really needed? Would a simple pipe like this right after the header that was capped eliminate a lot of low freq sound? Is the #2 pipe needed? I don't ever see that on the Helmholtz Resonator sites/videos.
This is on a race car, not a daily. Not concerned about noise. Just after the more "Exotic" high freq exh sound. This is for a 13:1 5.3 LS with ITB's.
Here's a video of the typical high pitched Corsa exhaust whine I was after.
#3 · (Edited)
I've run multiple resonators in the past and it quiets the note at all freq. ranges across the board. Attempting to quiet the low end frequency as much as possible while accentuating the higher pitch frequency sound.
Which is what I think the Corsa systems are doing. Just not sure the whole Helmholtz Resonator theory applies. Looks like its generally a pretty narrow RPM range used specifically to eliminate drone and not to eliminate the "muscle car" sound and accentuate the "super car" "exotic" sound.
Here's another good example of the two sounds I'm talking about.
#4 ·
You don't "cancel", or more correctly, attenuate low frequencies with short Helmholtz tube lengths. The first firing frequency in a V8 equals RPM/60 times number of cylinders. Frequencies lower than 250Hz have long wavelengths and are attenuated by an HH tube 1/2 the wavelength in length to achieve a return wave 180* out of phase with the regular wave, hence attenuation. There isn't enough real estate underneath a car to attenuate the first two orders of exhaust noise so the higher frequencies are targeted for "cancellation." Sorry, this is just the physics of sound.
The 180* headers have a basic sound property/idea built in with no mufflers or resonators. Sounds like poop at low rpms and "whoops" pretty good once the RPMs come up. There's no substitute for 180* cranks and headers on a V8 or siamesed 6 cylinders in a V12 for that sweet sound that ends up as a shriek at its RPM peak.
#5 ·
Appreciate the response.
Def not stating I understand the science of it. I just noticed most run a reletivly long tube length to cancel out drone at lower RPM. Then noted that the CORSA systems had what looked like a tiny "J pipe".
I was only trying to figure out why they have such a raspy "exotic" tone compared to the standard burble of an SBC exh systems.
The Corsa extreme line look like a straight through design for the most part.
But the Corsa sport look extremely different.
Here is another example. This is a straight piped setup with what looks like several separate Helmholtz tubes. Sounds great IMO.
#7 ·
I think that may be a big part of it as well. Only thing that makes sense. Which unfortunately sticks me with paying a lot for a muffler to vibrate... rubs me the wrong way for some reason.
Wonder if I could try slipping different thickness and length ribbons of SS sheet in the straight pipes and see if I can get one to resonate in a cool way! :LOL:
