I have seen many 9 inch setups but this one has a washer behind the axle bearings when pulling the axles out. Should it be there? It would seem like the axles would fit better without it as the bearing retainer is getting bent when installed to conform to the bearing protruding out from the tube slightly. Have you guys seen this or should this spacer not be in there?
Sent from my SM-G900V using Tapatalk
