Ok, i had a previous post a while back with my other car and here i have the same problem with my new car. Maybe im asking too much but here it goes.
Bickel built pro mod double frame rail running top sportsman
50/50 weight bias
708 sunset 1530hp tunnel ram
powerglide 1.80 first gear
33.5x17 Hoosier rear tires
penske double adjustable with air dump
Lonngggggg wheelie bars
I had my 4 link with 4.30s set at 53 inches out for the first year, it was doing ok but hitting the tire hard, problem is sometimes it would bite hard and id go red. Put 4.56s in for 1/8th mile and blew the tires off so decided now was the time to change 4 link. Moved my upper bars up one which moved IC to 61" with bottom bar slightly uphill. Ran good but was 2050rpms 1/4 second out but the track handled it. Had good spin on hit but still hitting tires hard (this was anywhere from 5.5psi to 6psi). Went back to 4.30s for 1/4 mile but i was hitting tires hard and dead hooking. First round they dead hooked, then spun then hooked again....my 60 went from .995 to 1.01 so i lost. I had launch at 4600 for first qualifier then went to 4800 for first round, lowered pressure from 6 to 5.7psi and lowered wheelie bars 1/4" but they still hooked. Also shocks were loosened 2 clicks on compression. Im squatting about an inch on the hit and its holding there
I cant for the life of me get these wheels to spin on the hit, even a slight bite and then break free. I cant lower wheelie bars anymore because of how long they are and i would be dragging them in the pits everywhere. Dont really want to run any lower than 5.5psi. I thought about getting after it and raising the launch to 5500 with the 4.30s to get them to break free but i feel like the harder i hit them the harder they bite
Am i missing something, besides being back heavy, my IC might be a hair high at 8.5"
Ill post graphs when i get to my track computer
50/50 weight bias
