far from it.
Having control over the blade gives access to a far wider range of control over the engine.
Whether for driveability, controlling power/torque, launch, traction control, idle control, anti-lag, safety etc etc.
And when you nail your foot to the floor....WOT doesnt always produce the most power/torque at every rpm, so with dyno time you can map the blade so it opens to produce the most power and torque when your foot goes flat down.
If you look at OEM pedal vs blade maps, they are often far from simple ! Although not so many aftermarket ecu's offer that level of control.
If all you're going to do is simply mirror the pedal 1:1, then you're right, there's probably no point at all changing.
And of course it makes cruise control easier lol.
