connecting headers without flanges to exaust.
1 reading
14K views 18 replies 13 participants last post by  cadmobile500
i just bought some 1-3/4x3" headers to replace my 1-5/8x3" headers.
the new header collectors dont have the 3 bolt flange. they are slip on.
what is the best way to connect these headers to my current 2-1/2" exaust?
should i just weld 3 bolt flanges to the headers and bolt them to the 3" reducers on the exaust if everything lines up?
thanks in advance.
#4 ·
thanks in advance.
I use v-bands.
#6 ·
A freind of mine runs a mud race truck, with that style collector. We used stainless band clamps like they use on big trucks, to connect his 3" exhaust system. They can be bought at Napa, etc, and most truck shops have them. They seal well and makes exhaust removal easy.
I use these on all the exhausts I build unless directed otherwise. Easy to use. Inexpensive. Available anywhere. Cut 3 slits in the end of the pipe 1.25" deep, 120* apart from each other. Makes install, and removal easy. Availabe in aluminized or stainless.
194902
#15 ·
Band clamps here. Like the kind you see in Chevell-Guy's photo (post #10). Never going back to ball and socket or worse yet, three bolt flanges; V bands and such are just expensive, large, require welding to install and require exact alignment. Band clamps are easy to assemble, easy to take apart, never had a leak, can't blow out, gives more clearance under the car and actually allow a little offset if needed. I use nickel anti-seize on the outside of the pipe that slips into the other pipe for ease of disassembly. My car sees a lot of miles and street time too.
#17 ·
Unless my muffler hangars fail completely, it's impossible for the exhaust to fall out (remember: street car). Even then, it'll take a herculean effort to separate them without loosening the band clamps. Sure, someone might forget to tighten them, but that could be said about many things. My dumps are held on the same way, and they've been there for years and thousands of miles. OEMs are now using band clamps in a lot of instances, and as mentioned above, big trucks have used them for years. I think you're missing out. Give them a shot.
