In my mind the best intake is one that has the minimum turns, correct CSA for intended use (rpm range, CID), length and the taper that works for that rpm range.
Turns in a manifold create losses. Minimize turns and power goes up. Tunnel rams (even without correct taper and sizing) shine in most cases.
Modern very high rise intakes (like NASCAR) have minimized turns that the air/fuel have to make. These do tend to be very tall manifolds - to increase runner length for tuned power range.
JMO of course.
