CAD/CAM software for hobbyist?
4K views 29 replies 14 participants last post by  rustang
What's out there that is reasonably priced? I was using Fusion 360 which was free to hobbyists/student..but it started asking me to download some app, and it really seemed to bog down my computer, and is limited now I think.
Any recommendations?
#9 ·
It depends on what you want to do.
I don't use an inexpensive CAD software so I can only say what I have heard from companies I work with that use the same high-end software I do (Siemens NX).
I have heard from many companies that are trying to save money for the basic work, that Fusion 360 does a good job.
I have some friends that work at AutoDesk, and even on the Fusion 360 project. One thing to be aware of is there will be a price hike on that software when they get enough users.
I would not use it if I needed to have forever access to the work I was doing. That rules out any web based app.
If you can tell me what you want to do, I can possibly suggest some alternatives.
I have also used MasterCAM but that isn't inexpensive and is not a good software for design.
#3 ·
I used to be able to find/get "cracked" Mastercam and even had the reps help me being a one man show. I helped get them into 4 shops previous so they looked the other way. But the young guns wanted to bust me for the software.
I think it was BOBcam that was respectable and cheap to buy. It all depends on your level of difficulty, type of work ( like 2, 3 or 4 axis) that would dictate what software to get. I have seen some shops run on purely the machines conversational programs and sub programs.
#10 ·
Depends what your doing... 2d or 3D....
personally I like fusion but idk what u did to it on your system
3D, it looks like the free for hobbyists is now limited to 1 year..
Define "reasonably priced"...
Say $500 or less.
Just fairly basic 3 axis stuff. I did like the simulator feature in Fusion..
I've read a bit on MeshCam..seems like a fairly easy to use software, basic, but might be suitable..
#12 ·
If you are limited to $500, but need good 3D, maybe you can see what they have at a nearby College or Urban Workshop.
If you want to do simple CNC machining, Fusion is good enough for basic stuff.
If you want to make anything like manifold castings, blocks or heads, find a way to get your hands on Siemens NX. Knowing that software opens up good job opportunities all over the world.
The easier to use software like Solidworks are good to know but if you think you might want to do it for a job understand that jobs using them typically pay about 1/2 as much as CATIA or NX. It is worth the effort to learn the more complex software.
If anyone has a question about using NX just ask, I will be happy to help.
#17 ·
#26 ·
Paying for fusion solves some of the problems found in the free version. There's a 33% off deal running now until 1/26, $330/year is hugely cheap for what it will do.
I've had Solid Edge and Edgecam for years, i just picked up fusion just to run one machine because it was cheaper than buying a code generator for Edgecam for that machine. So far I'm really impressed with it. I pay $1800/year just for for maintenance/support on a production version of Edgecam. Fusion will do things my version of Edgecam won't do, I'm considering dropping edgecam and continuing on with just Fusion. i'm not a fan of Autodesk, and don't like Subscription models or cloud based products, but oh well, if it's overall better for me, it's better.
