Anyone have the scoop on these heads? Seems like a little less or less refined version of the SR20's? Does anyone know what is the difference between a BRX and SR20?
the BRX are the as cast version the plus .200 in the intake height might be from the sr20's cnc machining but there are others out there that would most likely know more.Mark, the BRX has NOTHING to do with old style 24 or 26 degree heads?
"The revolutionary new BR X from BRODIX is by far the most powerful “as cast” conventional head on the market with a raised .300”, 444 cc intake port that flows 495 cfm! The exhaust port flows 305 cfm through only a 1.800 valve. This head features an efficient 100 cc chamber, as well as a valve angle rolled to 20 degrees. This new head is completely compatible with all existing 20° BRODIX components."
So looks like this is exactly the same as a SR20 head except that SR is .500 raised intake and these are .300 raised intake ports. Also BRX is 100cc chamber to the SR 95 cc. It has all the same specs and parts the SR20's have? Same valves, gaskets, valve size and angles, port cc's, everything the same as an SR20, but about $2,500+ less bare per pair.
Nice. What did it flow at 28” and at 0.700”?Here is a set I just finished.
Superflow 750 Frustration. Ported Brodix BRX Maxing It Out
Yes I remember some old posts way back mentioned these heads have longer intake ports so when you see 440 cc it scares people but the added length adds to the cc port volume but its not like a conventional head hogged out like those real old dart 410s.Swoop, I'm planning to use these on a pump gas street car 632. 1963 Corvette, the 2nd post has them in a pump gas street car too. Nyes racing has a 598 and 632 pump gas street car motors with SR20?? heads. Just of the top of my head.
Now I wouldn't try these on a 396 pump gasser street motor, but just maybe the as cast version would work on your 582.
