Bracket car turning sideways during burn out
578 views 13 replies 12 participants last post by  inferno camaro
700 HP BBC G body Powerglide. Only runs 6.40/ 106 MPH in 1/8 mile with restrictor plate. Same combo all season. Last 2 races the car wants to go sideways during the burnout. Leaves starting line like normal and goes down track normal. Had on lift and do not find anything causing it. Maybe tires? Hoosier CO5 14.5W. 85 passes. Wear holes still showing. What else?
#5 ·
When in the water box and the pull to one side is small. If you hold the steering wheel straight it will help hold the car straight. But of course when the pull is greater you have to compensate. I see some guys crank on the wheel as the rear moves to the side just an inch or two and it makes the situation worse.
#10 ·
Quite often when it starts up after being fine . Spring went away, shock leaking or adjuster not working. Heim that's tight. Put some one in driver seat and get under it and see if every bar is free. Diagonal also
  • Like
Reactions: 69427
