BLUEPRINT DYNO 396 SB
8.4K views 21 replies 11 participants last post by  Shovelhead78
Bought a 396 sb fron blueprint, came with dyno sheet, 511 hp at 5800, 517 torque at 4300, 15 initial, 35 full mech, which reading the spec,seemed a little optimistic to me. Anyway, I had an issue with the engine, not blueprints fault, i might add, so the engine was dyno'd again, only changes were a double roller timing set and an msd distributor. Figures this time were 465 hp at 5400, at 5500 , it dropped 2 hp and 503 torque at 4000, this was with 22 initial and 37 full mech. This seemed more realistic to me. I'm thinking of changing the blueprint dual plane for a vic jr, Iwould like to think it will pick another 15-20 hp at maybe 5800 or so. Car is fairly light, at a guess 3000# race ready, it has 4000 stall, 4.10 gears, so i think it will cope ok with the loss of torque at low rpm, as it's going to be street and strip. Would respect opinions on the intake swap, speak your mind, as it's only nuts and bolts to me.
Mike
#3 ·
Blueprint isn't the only place that sells engines with false dyno claims. Having said that, it is important to remember that every dyno will read a bit differently. You can bet your ass that most companies that sell engines and has an in-house dyno, that dyno will be "happy". Although, this isn't always the case. Find a good shop... build a relationship... use the same dyno (when possible).
With regards to your specific set up, what are cam spec's? My own experience is that a single plane doesn't always wake an engine up as much as we hope compared to an RPM Air-Gap for example (good dual plane).
#6 ·
There are several dynos in a 2 hour radius of me. They vary by 80 hp on the same engine.
Best advice I can give is to always use the same dyno just so you can have a standard to compare each engine against and just be ready to accept that it may be conservative or liberal. It's the guys that seek out liberal dynos just to "prove how good of a builder they are" that really get to me.
#7 ·
I have several friends with Blueprint Chevy engines. One is the 396 small block, two 489's and their 632. All run extremely well for the price paid, and also come with 36 month warranties.
The 396 SB is in a 3rd gen Camaro with a 4.56 rear. It's a low dollar build. Complete engine was $5000 complete ready to bolt in. Bought it right before Covid. Best run is 7.11 in the eight mile on pump gas all motor. Plenty of street/strip miles.
The two 489's were bought around 10-12 years ago. One 489 had a knock issue shortly after getting it. They told him to not take it apart and just get it ready for pick-up. They sent a replacement and swapped them out without hassle. This is in a beautiful C10 Square Body truck. Guy driving it is 72 years old. Has gone 7.20. 4.10 gear.
Other 489 is in a 1970 Nova. Street/strip all steel car. I believe it went 6.70 n/a, and 6.33 on a small nitrous shot. Zero issues with the engine. Currently has a 3.55 gear.
The 489's were bought by father and son. The other son upped the ante with the 632. lol Also pump gas. He bought it 8 years ago and put it in his 1971 Chevelle. It's a full weight, all steel car (minus the hood). With a 3.73 gear it ran a best of 6.34 @ 110. He tried a 200 shot on it last night, but only went 6.20. I think it might be his $400 Jegs brand converter. lol 632 is impressive. Has power EVERYWHERE. About any stall speed converter would work in the thing, as it has so much grunt. lol I think he just needs one that will handle more power. At the time, I believe he paid $12,000 carb to pan. Has been flawless. Blueprint dyno sheet said 830 hp, I believe.
All the guys went on a 1.5 hour long cruise, lining up with each other and blasting on them just a few weeks ago. Have done so several times. Nothing negative to say about Blueprint. For the price, power, durability and warranty... you just can't beat them for a ready to go pump gas 'crate' style engine.
There are Youtube videos showing their operation, and tours of their factory. Not your average 'rebuilder' shop.
#15 ·
That's definitely NOT the case. They design their own parts, have their own blocks and heads cast, go through great lengths to find good reliable performance combos that will last past the duration of their 36 month warranty, and have a lot of attention to detail. If I were in the market for a crate engine (which I am NOT) they would be the only one I would consider.
Below are some videos. Go to Youtube and type 'Blueprint Tour' for more.
Basic Shop Tour and how they do things.
Updated shop Tour, along with machining processes.
How the crate engines/blocks/parts are designed
Engineering Department along with Research and Development
(could be the most fun one)
Interview with the guy who founded the company.
#19 ·
Yes, but everything in the vavletrain needs to be correct; not overkill... just correct. Look at the entire valvetrain system, not just the cam and springs. In my experience, if you are seeing power really nose over past your current peak of about 5,800 rpm, it usually is a sign that the valvetrain is unhappy. If that is the case, it is probably costing you power before peak as well. Just something to consider.
#21 ·
We went to the prepped 1/4 mile event last night at Kentucky Dragway. This car belongs to my buddy, Scott. Back in 2016 he bought a 632 (carb to oil pan) from Blueprint. It's been in the car ever since. Only time he's touched it, is to fix a valve cover leak. It can be driven on a 2 hr round trip (if you want to buy that much 93 octane) or rip it up at the track. It's the engine rated at a little over 800hp. I think the dyno sheet said 830. Rev limiter is at 6800 rpm. It's backed by a 400 Turbo and 3.73 Dana 60. Full weight car with full original interior, back seat, dash, etc. Only fiberglass is the hood, and he had to install the SCAT Pro Car seats when he did the roll bar. (not lightweight racing seats)
The track had both 1/8 and 1/4 mile classes going on. He ran it both naturally aspirated and on a 200 shot of nitrous. He only made one n/a pass in the 1/8 early in day (80 degrees or so) and went 6.28. After turning on the bottle and it cool outside, it ran 5.84 @ 120 in the 1/8, and 9.15 @ 144 banging off the rev limiter. He was racing me... I treed him bad, and he was chasing my 9.29 @ 146. lol On a later pass, he quickened up the ramp and almost stood it on the bumper! Had never come close to doing that before. 275 Pro Radial on 10" bead locked Weld Pro Stars. He splurged on coated Lemons headers, and said they fit perfect and easy... well worth the steep price. 3.5" exhaust and see through mufflers. It ran 9.8 in the 1/4 n/a last time we were there. He didn't make any 1/4 mile passes n/a this time. He was having too much fun on the bottle. :)
Back in 2016, I think he paid around $12k carb to oil pan. I think they are around $17-18k now. He's talking about installing a 3.55 gear now, as the engine has the torque of an Army tank. lol
Anyway, if anyone was wanting a review and long term update on Blueprint, here it is. lol
