The Dart bearings having three holes just makes for extra leak paths. Their design was simply for installation purposes, not having to be picky about where they were put in at. - We run single hole bearings and cut the back band ourselves on stock diameter stuff, on the current 55mm cam combo I used bearings from Straub that are single hole with the band already machined in.
My stuff is 340-380# seat and 1100+ open, 8k+ rpm. The back band and clocked hole made noticeable difference in the bearing wear as well as the benefits of added oil control. I'm now toying with restricting the feed passage to them above each main.
Between notching the lifters for continuous oiling, then restricting the lifter gallies, and the cam bearings, we've been able to lower oil viscosity and slow the pump down/run a smaller pressure section (dry sump, on the previous wet sump we went to a smaller pump) while still keeping the bearings very happy. Similar peak oil pressure to what we've always run but lower idle pressure and much more linear curve. The dyno & the time slips have shown value in the better refined oil system & subsequent windage.
- I'm sure to the higher end engine guys, this isn't news.
