Springs AFR uses are Pac, but marginal for .800" lift. Retainers AFR uses are for triple springs, inner springs are not located by step. Valves are their spec, but are not the best quality or brand name. Shims under spring cups are not full outer diameter of cups, more like you would use for 1.550" springs. AFR and T&D don't seem to communicate on what shaft rockers to use on current heads. Flow ratings are specd with port adapters and radius' to make them look better. They push the hi ratio of exhaust flow versus intake flow in their designs, but that is just salesmanship. JMO.
Their castings are very nice quality. If you look at the price they charge for their assemblies versus the bare castings, you know those extra parts are not enough money to be the best quality. They say they sell those extra parts at cost to keep the price down.
2 intake ports on each head have marginal threads left for rocker studs after CNC porting. And no helicoils there either to help strength, if it would.
That being said, I have 357 CNC heads and have rebuilt a 532" pulling engine with 385 CNC. Neither have had any issues yet.
