ARP head studs
1 reading
11K views 38 replies 21 participants last post by  ordinary builder
You guys are going to kill me for the newb questions I have already ask and will probably continue to ask.
I'm about to install ARP head studs on my 496 BBC. The instructions say to tighten them "hand tight only". This is my first build using head studs, and I just want to make sure that this is correct. Do I truly only run the studs in by hand? No torquing them? Lock tight? Teflon?
Any help would be appreciated, and sorry for the dumb questions.
#9 ·
Silicone on them studs, run in be hand will never leak.........[/QUOTE]
EXACTLY^^^ I had to tear down a motor last fall that the builder had loctited the studs in they were a **** to remove. Had to double nut every single one.
I have bowtie block with blind holes on new build so I just thread them in with a little wd40 on the threads (so they dont rust in)
On everything else I've ever done its been brake clean the threads on both the block and studs (VERY IMPORTANT STEP) Then apply rtv to the threads of the studs, thread in hand tight only then slightly back off. Let set up, razor blade off the excess from the deck surface (if there is any)
#10 ·
If using silicone or Teflon thread sealant, be SURE to torque the nuts before the sealant cures, or it can compromise the sealant when you torque them later. There is clearance between the threads of the stud and the block. You want the threads in full tension before the sealant cures. A MUCH better process for proper torque. If you use non hardening sealant then it doesn't matter.
#14 ·
X2!
If the threaded holes in the block go into the water jacket, use a good quality THREAD SEALER. I use some stuff that NAPA sells in a small tin can. Apply it sparingly on the stud threads, then install them per ARP instructions - finger tight.
#19 ·
This is from Dart's instructions for their Aluminum Chevy race blocks:
Head Gasket & Cylinder Head Installation: You must use sealer on the head stud threads. Use silicone around all
coolant holes and head studs on both sides of gasket. Pack the counterbore around the head stud with silicone leaving a
small amount sticking up around the stud. This exact procedure should seal all coolant leaks.
http://www.dartheads.com/wp-content/uploads/downloads/2011/09/Aluminum-Chevy-Small-Block.pdf
#20 ·
Depends on blind or open to water hole for me. I use some arp lube or anti seize on the threads in a blind hole and pipe dope from Lowe's on one's with them going into water. The nice part about the pipe dope is it won't set like rtv until warmed. So it has a long working time.
