I'm looking to port some Mopar big block heads. I've never ported anything before but I have 5 sets of iron heads and I want to give it a try.
Gasket matching looks easy but I've read that the bigger gains are found by eliminating obstructions, blending the bowls and smoothing sharp edges around the valve guide bosses.
Exhaust ports are only slightly smaller than the manifold gasket from a Fel Pro gasket kit.
The 2" TTI header gasket shows some gains to be found!
Check out the step below the exhaust seats. It looks like when the hardened seats were installed, they didn't care to blend the sharp edge away.
Just a few minutes with the die grinder and most of the shelf is gone:
The guide boss edges are smoothed a bit too.
I know this may be hard to determine but is there any range of HP gains you can hope to get by some basic port work like this? You know, gasket matching, knocking down casting flash and bowl blending?
25 HP ? 30 ?
25 HP ? 30 ?
