1967 - 1969 Camaro Weight Reduction
1 reading
6.6K views 97 replies 23 participants last post by  Pro Stock John
Let's share ideas on weight reduction.
My '67 is 2970 w/o driver.
Iron 5.3 LS
S485 turbo
Fender exhaust
Air to air intercooler
Ron Rhodes core support
15 gallon plastic fuel cell
Full size battery
No front inner fenders
Factory manual steering
Gutted Stock dash
Strange manual brakes and master
Turbo 400
10 point mild steel
2 Kirkey seats
Full steel tubs
Ladder bar; coilovers
Ford 9", nodular iron center
Glasstek bolt-on trunk lid and hood; cowl panel
Sanders 15x3.5; MT SR 26x15s
Sanders 15x12; MT ET Street R 325 50 15
2025 plans:
Swap in aluminum 5.3 (-105)
Add removable chute (+15?)
Cut heater wings out of firewall and sheetmetal them (-8?)
Swap to bias fronts (-30?)
2840
+ 210 for me
+15 helmet, gear
= 3067 raceweight
Would love to hear your ideas.
#3 ·
You are reading my mind, I was thinking about doing one when I swap the longblock. Which one did you guys do on the Nova? It would be tempting to do an aftermarket column too, I wonder how much that would drop?
I'm going to keep it streetable, the occasional cruise to a little show, that type of stuff.
What other little ideas do you have? :)
#13 ·
Aftermarket column is easily 15lbs. Our old stock frame had the TRZ rack kit on it. Smith Racecraft makes a nice one too for the stock frame. Gotta imagine that’s easily 25lbs (ours was in it when we got the car). Aluminum spindles from TRZ were worth good weight with no downsides (other than cost). Coilovers on the front with 2.5” springs are definitely lighter than a stock mount style shock/spring setup. Would just need brackets for the top (readily available) and different coilovers. Look at the engine too- lot of weight can be saved with motor plates VS stock style mounts, turbo headers VS exhaust manifolds, etc… Even the turbo itself. Bullseye has some really lightweight units out now, not cheap though
#6 ·
this is close to the one trz used to make.
#12 ·
-SRC front subframe is very interesting, for now would keep that on the back burner I'd have to redesign parts of my turbo kit I think.
-I have Strange 4 piston brakes on all corners, manual Strange master.
-No front bumper, stock rear (hmmm could do aftermarket rear and aluminum brackets)
-stock fenders and doors, prob keep I can make my car asag legal with a few changes (I have 2 trunks and 2 cowl panels). ditto for glass.
-rack conversion and column is very interesting.
-Doubt I'd go smaller battery with the electric load I have with my setup.
-Lars the dash is completely gutted.
#14 ·
PA Racing – Your One Source for Custom Racing Suspensions
PARacing.com
https://paracing.com
Welcome to PARacing.com! Please browse around our site and check out our store for 1st,2nd,3rd and 4th gen Camaro suspension kits and Mustang suspension kits!
‎Contact · ‎Store · ‎About · ‎Customers
I bought a front clip from this place looks exactly like the Smith Racecraft clip for my 66 nova He sells one for your car as well
Read some people saying there not as nice as the smith Racecraft ones but I can tell you the welds like nice and it looks well made!
I have not bolted mine on the car yet ( bought it early this year ) but I picked this over the smith because it was in driving distance so I saved on shipping .... My buddy is starting a 63 nova build so we ordered two of them and I picked them both up!
#18 ·
My half birthday is coming up if you want to surprise me. :)
I'm wondering @18degsbcregal Vinny any little things I'm missing, I could take the whizzer wheel and cut some little brackets off the back floor and I never roll down my rear windows so I could make them fixed a a friend has done that. Gonna cut the side wings off the firewall at some point for room for my fender exhaust.
Definitely going to to a front steer rack now, SRC and TRZ have em.
#19 ·
Aluminum bolts for the front body panels (lots of anti seize), SRC trans crossmember fits a stock frame and is lighter than the box steel style or stock ones, rear seat belt attachment point backup plates can come off the bottom of the floor, smaller fuel cell depending on what you have in there now, aluminum lug nuts, lightweight steering wheel, minimize wiring, anything that doesn’t need washers, don’t use em, trim or replace bolts to be just long enough, optic armor windshield/rear window, any brackets that aren’t doing anything anymore can be cut off, stay away from billet catch cans and go for fabricated sheet aluminum ones, sheet metal trans pan VS a cast one is big weight, fabricated aluminum oil pan is considerably lighter than a cast style LS pan, sheet aluminum valve covers VS stock style or billet ones, try and make the charge tubes out of one welded piece of aluminum (minimize couplers/clamps), tubular driveshaft loop VS 1/4 flat steel one if you can fit it. Every little bit helps
#21 ·
Thanks for the detailed suggestions Vinny. Yeah I'm running a T400 cross member from one of the big Camaro houses.
I'm running a Grant steering wheel. I plan to at some point go over the wiring in the car, I can shorten some stuff and there might be a couple of lbs of extra wiring.
I'd really like to get the car to 2800 + 200 for me. But still street drive it.
Mrdragster noted on the driveshaft, I think I'd change my front tires to bias and before I sprung for a $1000 driveshaft (is that what they cost?).
#22 ·
PST has them, they start at $1,249
#28 ·
So race steering columns, decent on the street, do I need to do a lot of custom work to secure it?
I'll do the rack and steering column, and cut misc bits off the floor and clean up the wiring. Cut and sheet metal the firewall heater wings/coves. I'll look into an aluminum exhaust I'd do one of they hold up for a few years.
