1 - 5 of 5 Posts
CHECK THE DRIVE BELT THAT RUNS THE UNITS. MAKE SURE ITS NOT BROKE. ALLSO THERE IS A DUMP VALVE LEVER AT THE BACK SOMEWHERE MAKE SURE ITS NOT ENGAGED . IT BYPASSES THE FLUID SO YOU CAN PUSH THE MOWER. BOTH WOULD NOT GO BAD AT THE SAME TIME THEY ARE INDEPENDENT OF EACH OTHER.
one started going out and then a month or so the other one started to quit pulling also. the fan that cools them broke and i guess the units overheated. i didnt know the fan was broke and kept running the mower. it has over 300 hours on it.
O. ok. that sucks. should be the same unit thats in toro's timecutter. they'r not a servicable unit under toro. not sure how cub does it . its out of waranty ? how old is the mower ? 300 on a homeower unit is a lot
no warranty, its only 2 years old. my brother used it for a small lawn service business. its in really nice shape and runs great i just dont want to dump 1400 bucks into fixing it.
1 - 5 of 5 Posts
