1 - 7 of 7 Posts
I have a Yates headed 427,
Motor makes 760 crank hp if it maters, Quick fuel dominator.
Idles at 1250 in park or neutral.
When I put the car in 1st it idles the car down to 750 feels like it wants to die almost.
Its a race powerglide 9in race ptc converter, stalls to 4800 flashes to like 5200.
Any ideahs to why it does this.
Any help much appreciation.
Thanks tim
has it got a locked out dissy ?
The dizzy is locked out,
Thanks for the response so What would be the fix for it after I check balance between bowls
I have the same same carb. I do most of my idle setting with the rear blades. Mine has a tight converter and it will drop some but does not want to go dead.
1 - 7 of 7 Posts
