1 - 4 of 4 Posts
Couldn't get any real data cause the stupid computer kept defaulting after pass to dash 6 instead of dash 1 for logging.
Tried everything even changed dash 6 to valued info but just kept going back to original useless info.
anybody have similar issues logging, it has always worked till last weekend.
it sounds like the ecu is not saving the info after you reconfigure the data logger. One thing that i have found to do, is after setting up data logger then reconfiguring it, i always turn ignition power off to data logger, i also do this after each pass before i download the log.
later, JW
You changed it while online with the ecu?
Discussion Starter · #4 ·
TI sometimes power off but never had issues before.
I also tried to reconfigure while online and save. Reopened the settings still there but after pass it would magically change.
I have talked to FAST so there might be a outdated firmware upgrade.
Thanks for the replies
1 - 4 of 4 Posts
