1 - 3 of 3 Posts
I just tried to start the heap....the lights on the XFI....look like it is bank to bank...but I have it set on IPU and speed density.....this is on a small block ford....just watched the video from FAST....something hast to be wrong...plugged in per the instructions....it on the fifty degree ignition strategy setup parameters.
Could it be my 7531?
If I can't get it running soon...its up for sale!
IPU is for a crank trigger, unless you are using the distributor for cam only//
I plugged the distributor in and I believe I have it connected per the FAST instructions.....I have pointer on 50 degree mark.....I installed the distributor pointing to the back of the engine....turned it clockwise until I found a cam sync then further until I found the crank....I rotated the distributor counter clockwise found the cam sync and then the crank sync.....the only thing I can think of is I am on the wrong leading edge?
Greg
1 - 3 of 3 Posts
