1 - 8 of 8 Posts
Im new to the game and cant figure it out myself, time for some help.
So the question is how are these cars running the ladder bars? Welding the cross member and upper shock mount to the stock frame rails? or adding additional frame rails or what ????
Here is the official rule:
Complete stock chassis and frame rails must be retained. Back-halved cars are not permitted. Front core support may be modified or removed. Aftermarket bolt-on replacement front k-members/sub frames are allowed (if front shocks bolt to k-member then they must be in factory location). Mini tubs are allowed. Rear frame rails may be notched for clearance. Factory wheelbase must be maintained.
*Aftermarket rear suspension (ladder bar): add 50lbs.
I need help interpreting here.... I understand I need to keep the stock frame rails and can notch them for tire clearance but what about the rest of the floor ? What do they mean "complete stock chassis" ?
Thanks guys
My cross bar is welded to the factory frame. But I would think that you could do either one as long as factory frame is retained
How do ladder bars work with the Hoosier ?
1 - 8 of 8 Posts
