Nah you and kevin have already proved that's not the case. LolYou also have a nitrous expert in charge of that thread that says multiple systems will make more power, as will a tunnel ram.
Single stage weight brake?????????????
Lol just making sure.I saw it, LOL!
You need 3 systems with .026 jets, bank them FO 6 STAGES OF NITROUS!!!!!! It will be just like Pinks All Out!You also have a nitrous expert in charge of that thread that says multiple systems will make more power, as will a tunnel ram.
Shit we are all out & can only run as fast as you & we are leaning on it..You also have a nitrous expert in charge of that thread that says multiple systems will make more power, as will a tunnel ram.
You still have your weight break really. Sbnos got 50 off so you are the same as last year. LolYou also have a nitrous expert in charge of that thread that says multiple systems will make more power, as will a tunnel ram.
Randy you have to agree you seen two bbnos guys say sheet metal dual carbs would slow them down in this class. So I am thinking -50 if you have one those pos sheet metal intakes.Oh boy!!!!
I was thinking the new seats should be carbon firber....just sayin'.Will any proposed rule changes effect the use of sheet metal seats, if so where can cast aluminum seats be purchased ?
If I had the money to buy 3 kits they would have 32-40s in each one! Hell with that banking, I would leave on my middle sized jet, have the secon one all in, in .1, and the third all in, in .15!You need 3 systems with .026 jets, bank them FO 6 STAGES OF NITROUS!!!!!! It will be just like Pinks All Out!
There's your problem! You need to quit leaning on it and start working on it!Shit we are all out & can only run as fast as you & we are leaning on it..![]()
Yep the same as last year, chasing all the big power guys with a little ole' SBN20 car with its tongue hangin out!:smt073You still have your weight break really. Sbnos got 50 off so you are the same as last year. Lol
It's all that phucking HP back off the spray a little & it's easier on parts. Team South TTFMF'SI need a wieght break! I KO"d a planetary , input shaft , hub, pump and converter! When vader comes out maybe you'll see we all need wieght off lmao
