1 - 4 of 4 Posts
is it worth trying to keep up with x275 with my brodix track one heads and x275 88mm turbo. i know my heads are a very limiting factor but can anyone chime in and let me know what they think about it. everything else i have will handle the power that turbo will support. any help would be great
Try it and see what it does. At least be able to get some runs on the car and sort out some bugs.The only drawback I can see is with your headers fitting your heads and also be able to upgrade to some better heads later.
I honestly don't think you will be competitive with those heads. I would look at 245 AFR or All Pro in 23* but something in either 18*or 15* would be much better for little more than the All Pro's. The AFR is probably the most head per dollar. They offer a spread port exhaust that has better cooling between the two siamese exhaust ports. They have a inconel exhaust valve option that with the PAC 1225 springs and Ti retainers and bolt on and go. RFD for 18*or15* offerings if you want something pretty bad ass without going big money for symmetrical/canted valve head which is the ultimate. If you just want to race keep the Track 1's if you want to win look at these other options. Hope this helps.
you might be surprized at what those heads can support. i went 7.40's with them. kuntz has good programs for those heads if you want to max them out.
1 - 4 of 4 Posts
