I'm hoping those in the know will be able to shed some light on question I have. I currently have a 351 with AFR 165 heads, cam is 214/[email protected] w/ .477/.444, 114LSA, GT40 FI intake, 1-5/8 Longtube headers, and a 70mm tb. The truck it's installed in is Speed Density so it is very camshaft sensitive. I'm saying that because I'm pretty set on keeping the camshaft.
I have another car that I'm considering heads for. I was thinking of swapping the 165's off the truck onto the car, 1995 Cobra. I would be in the market for some new heads for the truck. I saw that the AFR 185's flow more than the 165's but at about the .450 lift range and up. At .500 they outflow the 165's by about 23cfm on the intake, but the exhaust is the same. My camshaft only has .477 and .444 lift so I'm assuming the difference in flow is even less at that lift point. Would I benefit by upgrading the heads on the truck to the 185's or should I just leave them as they are and put the new heads on the car?
