1 - 6 of 6 Posts
I currently have a 381ci sbc in a mustang actually just got done with drag week. Car ran without any problems actually got 2nd place to a really fast pinto! I now have a gt4788 turbo on it I just want more! Thinking of going with twin 6765 billets or the 76mm billets. With the gt4788 on it it only makes 24 psi on kill and I just would like to be able to push it to 30-35 psi if I need to! The heads are afr 210's cam is .630 .630 252 248 on a 116. I am just worried that if I put 76's on it it will not spool for crap! compression ratio is 8.75-1 bore is 4.020 stroke is 3.75! Thanks for your info!
What numbers you currently running at what lbs?
The fuel is E85 and the car weight is 3800. It makes 920 to the tire on a mustang dyno at 24 psi. At 20 psi it runs 8.90's at 154 mph.
1 - 6 of 6 Posts
