1 - 1 of 1 Posts
I'm looking to install coilovers and noticed the Wolfe setup is different from the team z setup. Wolfe hangs the shocks off the rear of the bar and doesn't require the spare tire well to be modified. Team z mounts the shocks off the front of the bar and you need to remove the spare well or notch it significantly.
My question is for the wolfe setup users....has anyone ran into issues with the differential hitting the shock bar on car with low ride height???
1 - 1 of 1 Posts
