1 - 10 of 10 Posts
I have a Moroso oil filter adapter that takes either a Wix 51222R or a Fram HP6 oil filter.
I cant seam to cross the wix # to a conventional filter #. Im sure they make one and I know Chris U uses a conventional style.
Anyone have any info on this?
Thank you in advance!!
Chris, this darn adapter takes a 1 1/2-12 thread!! I would like to change the adapter but will have to keep it for now.
Thank you!
Mark
Outrunning the Big Blocks
Thank you!
Mark
Wix says race apps only.
Part Number:51222RUPC Number:765809120471Principal Application:Racing Applications Only</B>All ApplicationsStyle:Spin-On Lube FilterService:LubeType:Full FlowMedia:PaperHeight:6.210Outer Diameter Top:4.600 Outer Diameter Bottom:Closed Thread Size:1 1/2-12By-Pass Valve Setting-PSI:18-22Max Flow Rate:28 GPM
Gasket DiametersNumberO.D.I.D.Thk.Attached 4.320 3.820 0.365
Thats pretty much what I came up with also.
Thanks for checking!!!
Mark
Call your local NAPA autoparts store. The Napa filters are WIX and they stock damn near every number they have ever made an can usually order anything that WIX makes.
Add the PurePower that is made specifically to replace those two filters on that adapter and you will get 74 gallons per minute flow and that is a bunch. It is expensive but you buy it only one time.
Ed
Can't you use a regular GM thread in the block? WE have one for that too that flows at 38 gpm and filters down to 12 micron but is rated at 22 micron absolute.
Ed
Discussion Starter · #9 ·
Ed
Thanks for replying Ed, wish I could. Its a external pump deal and the filter portion of the block has been milled off!
1 - 10 of 10 Posts
