1 - 1 of 1 Posts
I received a set of off the shelf BBC Quick 16 pistons. They appear to be a good design, have skirt coating, deep valve reliefs and .043"/.043"/3 MM ring grooves that do not intersect the pin hole, so not ring spacers needed.
The weights are written on the bottom of them too. 7 of the weights are with 1 gram verified. The eighth piston was 8 grams heavy. I called Vic at their tech dept. and asked about it. He apologized for that and sent me a replacement that was within 2 grams next day, no charge.
It was kind of a mistake on their part, but they made it right promptly so that is a sign of a company trying to get better.
1 - 1 of 1 Posts
