1 - 3 of 3 Posts
I know the soleinod on the trans has 2 wires one is a ground but does the other go to power or the wire from the 2 step in the 6 box and still need power?
12 volts to one side of the button
Other side of the button needs to be split.One wire goes to the digital 6 launch rev limiter,then the other wire goes to one side of the trans-brake solenoid.
Ground the other side of the trans-brake
Unless you are using a delay box then it depends on which one.
Yea no other stuff hooked to it thanks I'll give it a try
1 - 3 of 3 Posts
