1 - 12 of 12 Posts
Hi All,
I have at trans brake wired into the car, it is currently activated off push button on the gear knob, the trans brake is dual function as I need to activate to reverse (Glide) as well as using for launching
I was looking to wire the trans brake into a RPM controller for launching, how do I go about by passing the RPM launch for normal reversing ?
What RPM controller would you recommend ?
Childs guide/drawing for wiring installation would help :rolleyes:
Cheers,
Mark...
you could flick a change over switch to apply power to the button on the shifter for reverse and then apply power to the rpm module when on startline side of switch?
Dan
Discussion Starter · #4 ·
I don't think you would ever see launch RPM's during backing-up!
No my point was or how I was thinking, which now having a rethink maybe wrong !:rolleyes:
So if I install a RPM switch, Will it limit the maximum RPM to the RPM's as on the Chip or will not activate until the chip RPM is met ?
ie If I have a 5,000 RPM chip, does it disengage Trans Brake when 5,000 RPM is achieved.
Or can I release the trans brake button, any where between 0-5,000 RPM ?
If this is not the case, then I dont have the problem I thought I did, if that makes sense
Sorry for not making it clear on what I was trying to do ?
I was thinking of using a RPM controller, so I could determine what the launch RPM is, when the trans brake is released.
I thought that RPM controller only became active, once the predetermined RPM is met & that these switches work by either grounding a circuit or opening a circuit. So when determined RPM level is reached solenoid is activated, until released. If I use a RPM Switch I assume it will stay powered anywhere above desired RPM , which is not what I want to do, so Not sure if I can do that with a switch ?
My Powerglide also utilise the Trans brake for reversing, naturally I don't want to reverse at 4,500RPM or what ever chip is used :)
If can wire in a RPM Controller for the Trans Brake to release at determined RPM, but not sure about what to do, when I want to reverse ?
Ideally I would like the option to:
a) Select RPM Module when using Trans Brake at the track
b) Use the trans brake for reversing
Will the 2 step do what I want to do ?
Yours Confused . . . .
Discussion Starter · #7 ·
Maybe I should forget the RPM switch & just release the button once I have reached the RPMs I want & continue to press the Trans Brake for normal reversing
you could wire it onto the same arming wire for the 2 step mark, so that when the 2 step is engaged it also gives ou a rev limit , only thing in reverse you would have a rev limit but im sure that wouldnt matter, do you run your 2 step through the bs3?
Dan
Discussion Starter · #9 ·
I did run it through the BS3, but when I hit the Trans Brake, the motor stumbles almost dies, almost as though it is overfueling..... I have tried numerous things to try & cure the problem in the BS3, but to no avail
you don't want to wire the t-brake to an rpm controller. Then you don't have controll of when it launches, it just leaves when you hit that rpm. You want it on a 2 step rev limiter!
Anytime:smt066
1 - 12 of 12 Posts
