with the colder temps my hesitation gas gotten a little more pronounced-I never got rid of it all the way before (Holley HP, LS/Procharged/LS3 heads, intake, Fast 92 MM TB)
I tried a little of everything, but not one thing really made a diff, but a little of everything helped
the blanking on the V2 was supposed to help the off idle problems, but I am not sure how low you can go-they say to low can cause some idle problems-I have it learning at idle, not sure if that is hurting it or not
when I data log it, I can see the lean spike and the map follow it as it hesitates-I tried lowering the AE vs MAP Roc Blanking, and the AE vs TPS, but seems it wants something else-with the 325 gears, there isn't a lot of throttle movement at lower speeds when it does it
WOT is instant, it will blow the tires off until I lift, so its something as in like stopping at a light and taking off, or just a little off/on the throttle
I didn't know if the AE Corrections TPS would do much, I think im at around 300 in the area it hesitates
