1 - 7 of 7 Posts
· Registered
There are many good inexpensive combs available it just depends on what you are trying to accomplish. In Liberty Dan
· Registered
Discussion Starter · #4 ·
I'm not sure what you mean by 'trying to accomplish' this engine would be a street strip engine on pump gas, 11:1 comp, I suppose I'm trying to find out the differences between scat,eagle, probe,callies etc 4340 cranks/rods, have only ever used a scat crank/rod before that worked out ok! What to use what to stay away from.
· Registered
The cast steel Scat/Eagle cranks work good for what you are trying to do. I would go with some type of 4340 rod and a Ross or Probe forged piston if money is real tight we have used one of the Hypereutectic pistons (KB) up into the 475 hp range. In Liberty Dan
· Registered
I think mainly Dan meant, how much power are you wanting to make, will it be drag race only, road race, street only, nitrous/boost, etc...
There are the cheaper $1000 kits that will hold up about as well as a stock 351 late model block. Say around 600-700 fwhp at most. Then there are the forged kits out there that can handle 1000 horsepower plus with supporting parts.
Is this going in a 75 and newer block, or in a 69-74 block? The older blocks are stronger and would make it beneficial to go with all 4340 stuff so you can handle more power in the future.
I have all Eagle 4340 crank/h-beam rods with Ross forged flat tops on my combo. No problems so far with around 650 n/a and 750-800 (maybe) on nitrous. I plan to make some more n/a and hit it with 300 this year.
1 - 7 of 7 Posts
