Hey guys I'm building a new shortblock using a shp block. I plan on re using my 21017 pan. I know some guys have had windage problems with these pan. My last motor had 70 pds of oil all threw the burnout and while i was on the 2 step. As soon as I launched it would drop to 40 for the whole run until I lifted at the shut down. Does this sound like more the oil going up the back of the pan. Should i put one of those moroso baffles that go on the main cap. Thanks. Even though bearings looked fine in old motor would like to correct this. Also old motor had a moroso hv pump. I was going to go with a standard per dart for the shp block.
