1 - 3 of 3 Posts
Which is better, a Canton screen type windage tray or the baffles that came on my oil pan. They are interferring with each other. Should I cut out the baffles or run without the windage tray? My pan also has a trap door in it to help hold the oil.
I would rather have a real good windage tray and a good scraper. The pan just needs to keep the oil from sloshing around and running away from the pickup. I usually modify the pans in the sunp area as well as run the piece that bolts to the pump which blocks oil from rising up the back of the pan on launch.
Thanks Kris,
Could you send me a picture/drawing of what you make that bolts to the pump? I would be interested in buying one, if you would like to sell one. Also not sure what a scraper is?
1 - 3 of 3 Posts
