1 - 2 of 2 Posts
Steve Morris Cam valve adjustment intake .02 exhaust .026
gross valve lift intake .662 exhaust .665
duration @ .020 tappet lift intake 270 exhaust 281
valve timing open int. 9 exh. 60 closed btdc 59 bbdc 10
These specs are for cam installed @ 115.0 intake center line
duration @ .050 int. 248 exh. 250
lobe lift int. .4140 exh .4160
lobe sep int.115
My setup is compR 83mm turb with 87mm compressor wheel, TEA TFS 225 high ports super vic intake, csu 750 carb, 2spd powerglide neal chance convert, 10.1.1 comp with flat top diamon pistons, svo 351w block stroked bored to a 408. My goals are 900-1000hp street drivin here and there.
Yup itll work. Install it on a 112 intake centerline.
1 - 2 of 2 Posts
