1 - 7 of 7 Posts
TEAM NORTH
I have a 383 SBC
-Dart Pro 1 215 full ported by S.A.M
-13 to 1 comp
-1.6 rockers
-Super victor intake fully ported by S.A.M and intake matched
-950 carb
-300 shot nos
Will this cam work for me? Strip car only heavy nos use
luniti cam specs .900 base circle cam solid roller at 50 278/286 LIFT 679/630... lobe 108.... lash .24..... rpm 4000-8000
Butch
I have a 383 SBC
-13 to 1 comp
-1.6 rockers
-950 carb
-300 shot nos
If you want to stick with Lunati go for the 50132 for a N/A cam (317/330 @.020" 283/291 @.050" .680"/.632" 106°) or use the camshaft below
307/313 @.020"
278/284 @.050"
199/204 @.200"
.723"/.723"
106°
With the 300 shot, if your wanting max performance on spray, I would widen it up some and take a little intake duration off (~8°) or a different profile like cam below
For spray,,,
298/314 @.020"
268/276 @.050"
191/190 @.200"
.670"/.625" with 1.5's
.715"/.666" with 1.6's
108° lobe center
If this is going to be a heavy nos set up I would use a custom cam designed for you and not a off of the shelf grind, I mean it's only a few dollars more and well worth it imo. I would be more prone to saying a 270/282 @.050" cam on a 112+4 would be more along the lines of what you would need imo.
TEAM NORTH
How is this if I change the lobe to 112 or 114 ?
Dur Int-Exh: 310/322
Dur @ .050 Int-Exh: 275/286
Lift 1.5 - 1.5 Int/Exh: .652/.643
Lobe Center: 110°
Valve Lash: .030-.030
RPM Range: 4500-8000
And what would this be with a 1.6 rocker?
Butch
Second cam I posted, 110° to 113° lobe center would work well depending on a few things about the engine
1 - 7 of 7 Posts
