will a r block fit in a dart block. The dart is 2.081 common journal size
snoopstang · Registered Joined Jan 22, 2008 · 845 Posts Discussion Starter • #1 • Jun 24, 2012 will a r block fit in a dart block. The dart is 2.081 common journal size
O ordinary builder · Registered Joined Dec 18, 2009 · 13,485 Posts #2 • Jun 24, 2012 same ,....unless someone machined something differently....Lobes and journals are in same position bearing diameter is stock 2.082 journal...
O ordinary builder · Registered Joined Dec 18, 2009 · 13,485 Posts #3 • Jun 26, 2012 you can have the block changed to use all the same diameter or to be same as stock bearing s that are all different diameters... ....
