If you go down to 10W-30 it will come down a considerable amount. If that's still not where you want to be you can always try something like 5W-30. You could also go to a full synthetic but I would run at least 25gal of fuel thru it before switching to synthetic to avoid any possible ring seal issues. To me the full synthetic seems thinner than conventional oil with the same rating, especially when it gets hot.I just worry about 100plus oil pressure and pumping pan dry. I know the bushing resist oil the top but 100psi worry me. i hoped someone has ran this pressure in my setup. I hate to pull front k member to pull oil and change spring in pump.
Yes it would.if I'm thinking correctly the higher pressure should not effect the pan from pumping dry, wouldn't it have more effect if the pump was high volume vs high pressure?
Uh, not necessarily.Yes it would.
My 408, runs 3.25 on mains 2.75 on rods and I run 5w30 mobile 1 with a melling 10335 and oil pressure hot is 25-30 at idle and 60+ over 2000 rpm, I have considered going to 5w20 mobile one, biggest thing, make sure bearings get adequate oil flow for cooling, best way to do that if the motor is tight, is to lower the viscosity, you see OEM's doing that now, tighter motors, lighter oils, electronic pumps to drop oil pressure more. the bigger clearances help keep oil out of the top end, and keep the mains and rods fed really well, a good windage tray and crank scraped and it works great.Rods .0028 and mains ,0030 also i have lifter bushings with the small holes. Oh the break in oil 15w 40 diesel oil with comp break in additive.
I bet that bad boy 408! makes over 4000 hp ya lol ?My 408, runs 3.25 on mains 2.75 on rods and I run 5w30 mobile 1 with a melling 10335 and oil pressure hot is 25-30 at idle and 60+ over 2000 rpm, I have considered going to 5w20 mobile one, biggest thing, make sure bearings get adequate oil flow for cooling, best way to do that if the motor is tight, is to lower the viscosity, you see OEM's doing that now, tighter motors, lighter oils, electronic pumps to drop oil pressure more. the bigger clearances help keep oil out of the top end, and keep the mains and rods fed really well, a good windage tray and crank scraped and it works great.
and engine are lasting longer then ever with each year having successively high outputs.
about 1400 on pump gas all in, shifts at 8500 and is street driven weekly and daily all summer with the air on in traffic.I bet that bad boy 408! makes over 4000 hp ya lol ?
Cool beans have any vids of that bad boy ?about 1400 on pump gas all in, shifts at 8500 and is street driven weekly and daily all summer with the air on in traffic.
nothing from last year, we spent the last 2 yrs breaking the valve train, had a balancing issue that ate up the mains, and nipped a piston , really loved pulling the heads off to fix ripped out threads though. I might post some up come spring. trying to get out to the track now that it isn't ripping the valve train up.Then again, the guy I partner with on it, likes to grudge it, so it is unlikely. If I get around to putting one of my other projects together I might post vids. If your planning to call me out, don't bother, I have done work for a ton of people on bullet, don't waste your efforts.Cool beans have any vids of that bad boy ?
Naaaaaaa no need to call you out hell I was even thinking of having you build me a new short block maybe with your cam , pistion, oil , and head designs I could make more hpnothing from last year, we spent the last 2 yrs breaking the valve train, had a balancing issue that ate up the mains, and nipped a piston , really loved pulling the heads off to fix ripped out threads though. I might post some up come spring. trying to get out to the track now that it isn't ripping the valve train up.Then again, the guy I partner with on it, likes to grudge it, so it is unlikely. If I get around to putting one of my other projects together I might post vids. If your planning to call me out, don't bother, I have done work for a ton of people on bullet, don't waste your efforts.
BTW I used to be a heavy oil guy, I have seen the light, and the engineering data, and it says, heavy oils aren't the greatest, that's a carry over from the old days when we didn't have multi viscosity oils with the type of additive packages we have now, and tolerance control was abysmal.
You'd ware your window out having to stick your head out to see if the rings are sealing..Naaaaaaa no need to call you out hell I was even thinking of having you build me a new short block maybe with your cam , pistion, oil , and head designs I could make more hp![]()
