Gates open at Noon Central time....
Rules
1. Door cars only * Heads Up * 400 Pro Tree * 1/8 mile * Race Entry fee of $100 will be collected at the gate * Total entry fees collected will be paid out as purse. * Wild Street will park and be teched in the oval track area. * Two qualifying sessions will be run and cars will then be placed on a pro ladder.
2. Tire size limited to 28 X 10.5 non W slick or 275 X 60 drag radial or 28 x 11.5 et street.
3. Power adder is limited to one stage of nitrous on plate or fogger, if fogger is used an additional 50lbs. must be added. If car is equipped with 2nd kit it must be capped off.
4. Cast intake only.
5. 4 link or ladder bar cars allowed. Coil overs are allowed, coil can be moved inward for tire clearance. Mini tubs are allowed. No whellie bars. Stock firewall and factory front frame rails are required.
6. Fiberglass is limited to hood, bumpers, and deck lid. Lexan windows allowed.
7. Must have stock appearing interior with two racing seats.
8. Rear wings allowed.
9. Small block N/A - weight with driver 2600
Small block NOS - weight with driver 3000 with non conventional heads * 2900 with conventional heads
Small block with Turbo up to 88mm - weight with driver 3300
Small block with blower - weight with driver 3200
Big block N/A - weight with driver 2800
Big block NOS _ weight with driver 3300 with non conventional heads * 3200 with conventional heads
10. One carb only on NOS combo's.
11. N/A cars must add 50lbs. for additional carbs. If sheet metal intake is used 50lbs. must also be added.
12. No reducers in the turbo true size only.
13. No boosted big blocks allowed.
Correction:
No scales and 29.5 x 10.5 non w max tire size. All other rules
apply.
Rules
Correction:
apply.
