1 - 9 of 9 Posts
I have both upper and lower in my car. It takes some time to get all of the spot welds, but they are very nice pieces. Probably a day to do the upper.
YOu mean to drill out the spot welds to remove old torque boxes?
I just seen my passenger side is ripping away from the car.
Remove and install in a days time.
Discussion Starter #7
Looks like its probably the easiest upper toque box install. The guy who mounted the upr anti roll bar who had car before me welded it right to the rear edge of the torque box where it mounts to subframe. That will be fun to get cut loose.
Discussion Starter #8
Just talked to them Super nice people. I ordered the uppers and a battle box reinforcement for the lower. They told me to mock it all up and see if we need the lower battle boxes. I can return the reinforcements if needed. Sounds easy to install to once you get all the spot welds drilled out.
How much welding was done inside the car?
All welding was done under car. I made a reinforcing plate to go inside the car and bolt thru the top of the s-box.
1 - 9 of 9 Posts
