1 - 14 of 14 Posts
What can I do if i have true dual exhaust? Do they make anything to take 2 sensors and calculate into 1 gauge?
One sensor in one bank is adequate. The sensor is really only a basic reference to go with plug reading and if you want cylinder specific data, 8 egts.
Posted via Mobile Device
Simple fix...I took a single pole double throw toggle switch and just toggled between the two sensors to one AutoMeter gauge.
I did the same with my Innovative LM1, worked out great. After viewing the log from a couple passes and changing jets we picked up a couple tenths.
On the roller...
Does it read any different then if the o2 sensor was mounted closer to the head? Always wondered this.
Keep it up around the collector if possible. Keep it in heat...
Check out the units from Daytona Sensors...they work very well and have one's that come with 2 sensors and even one that will log A/F.
We use a WEGO III that is interfaced to our RacePak but you can use them stand-alone as well.
1 - 14 of 14 Posts
