I have a 710" bbc with two foggers, 42/32 in first and 34/22 in second. 30* base timing pulling 14* on first and 9* on second. Still no timing mark, heads are Brodix big duke 16*. Compression is 14:1. I figured being that these are 16* heads that they wouldn't like a lot of timing. I dropped retard to 12 on first and 8 on second. Still no mark on strap. I don't run o2's but I do run egt's. After adding second kit egt's are around 1500-1600 degrees. They use to stay around 1200-1300 degrees.
