I have a sbc with a YSI on it, the mounting bracket that came with the kit is way flimsey. so to help I put a head unit brace to the crank and that made the serpintine setup work good but it would slip when tryin to make higher boost. to get some boost numbers I put a cog setup on it, the problem is that Ive ripped up 4 cog belts now and havent made a full pass yet:smt093. I made some changes and put the head unit brace in place and thought that would help but Im still throwin belts. why did vortech put out a kit that will not hold a belt? the ford stuff is solid but the sbc stuff is horrible. Im gonna add another plate to the mounting plate like I seen a pic on here of, if that dont work I may be switching to procharger. its not like ive spared expense to make this work but nothing has worked yet. (rant over)
