1 - 20 of 83 Posts
looking into doing an LS motor, who is making big power n/a, what heads is everyone using...ls3 ls7? and what what intake..no sheetmetals
Moderator
School of Automotive Machinist(SAM) is making huge LS power.
BES Racing Engines made 1k plus with new GMPP DR heads and DR intake, single carb.
and I know they are working on another motor to shove SAM out of the All Motor's top spot.
should be very interesting year next year for the LSX series.
i know of a c5r about two years ago a guy i know had made 940 na
090 c5r or DR heads if you don't mind the extra cost.
As far as the manifold is concerned... the no number P7 manifold is the ticket.
If you don't mind a cast tunnel ram the M&M tunnel ram can make some steam with some work.
Depending on your wallet size and goals Mast, All Pro (WCCH), and RFD makes some very nice heads that are easily capable of over 950fwhp. IMO Mast makes the best cast single plane intake.
Any more info I'm your lq4 combo? Thing runs good for 3800 lb tank. Who did your cam?
x2
10xxhp
bes all the way
the rest guess................:drinkers:
1 - 20 of 83 Posts
