1 - 10 of 10 Posts
· Registered
Do you guys ever see cars at your local tracks that don't have all the lug nuts? I can't tell you how many cars owned by select groups that don't have all the lug nuts down this way...
At first I thought it was a 5 lug thing, 4 would be installed. Perhaps not all packages have 5 so 4 packs of 4 get installed. But just last night I saw the typical Weld 4 lug setup on a car that only had 3 lugs per wheel many of which were different style or brands. It baffles me that people are so damn cheap they can't put lug nuts on every wheel. I should start taking pictures.. might help answer this better. :rolleyes:
· Registered
It's only the manufacturer's OPINION that five lug nuts are needed.
The factory used 4 lug wheels on small street tire cars with low performance power plants and that would probably be based on some testing not just some guys opinion. 4 lugs work for that but for a hi powered car with high traction tires 4 lugs seems silly and factory cars used 5 lugs for those. I have seen several fast fox body cars with 4 lugs run in the high 4 second range and it amazed me they got thru tech. I sheared 5 lug wheel studs with much slower cars.
· Registered
Discussion Starter · #9 ·
Did you understand the first post? :confused:
· Registered
I was joking.
1 - 10 of 10 Posts
