1 - 14 of 14 Posts
Yes,
just like in nascar, does anyone know who sells the restrictor plates. I think most are managed by nascar but I would think that someone sells them...who??
Thanks, AMXTRA
You got it...Trying to slow a car up for the 1/8 mile 6.50 index races without making other changes.
Allstar Performance
Adjustable Base Plate
ALL26060 The "Governor" is a 1" thick, four-hole aluminum spacer with tapered inserts which may be quickly changed after removing the carburetor. Restricts air/fuel entry and reduces power slightly to prevent wheel spin. Inserts range in size from 0.950" to 1.400" for custom tailoring for quicker lap times. Fits all Holley 4 bbl. 4150/4160 series carburetors.
ALL26060 Adjustable Base Plate
Suggested Selling Price: $59.99
ALL26061 Base Plate Insert 0.950"
Suggested Selling Price: $31.99
ALL26062 Base Plate Insert 1.000"
ALL26063 Base Plate Insert 1.100"
ALL26064 Base Plate Insert 1.150"
ALL26065 Base Plate Insert 1.200"
ALL26066 Base Plate Insert 1.250"
ALL26067 Base Plate Insert 1.300"
ALL26068 Base Plate Insert 1.350"
ALL26069 Base Plate Insert 1.400"
There are different size plates depending on how much power you are trying to cut out/lose. I used to work within the NASCAR Series, and there are a few guys on here who are still in the series as well that may chime in. If you are looking for them they can be purchased from my prevoius employer BSR Products (The Phuckers) - Located in Concord NC
Discussion Starter #8
Thanks for all the info guys. This will get me off to a good start.
AMXTRA
Discussion Starter #10
This is what I've been looking for. Thanks for the info.
AMXTRA
Discussion Starter #12
at lease .500 or slightly more based on weather conditions.
This adjustable plate would be great and a log could be kept for settings. I have also thought of an adjustable throttle stop.
Having to reset timing and pull shift points back are just too much.
I do like the Willys plate because it's a bolt-on that would not have to come off. AMXTRA
1 - 14 of 14 Posts
