Guys,
I am looking for a new C4 with brake to handle up to 700hp.
Who do you recommend?
Rod
Rod
THERE IS NO GOOD C4 PUT A T400 IN IT.
I'll second Joels. Anyone I've known with a Joels trans is more than happy. Plus, he good to talk to, nice guy, and shares knowledge of what and why. I now have one of his and its bullet proof. Its behind a 700hp URE mill. CALL Joel!!Joel did mine I had 2 Hughes that went down he redid the last one and no issues. I run a BBF (460) with a C4 behind it we have 120 or so passes with no issues
Joel's on Joy
(313) 581-6266
20901 Joy Rd, Detroit, MI 48228
ok just don't get dynamic trans confused with proformance trans/dynamic convertors two totally diff companies..... shawn and frank at proformance trans are the best by far!!!!Hey guys this is my first post as I have been on for a while but haven't registered. Until this thread.
I will never buy from Dynamic again. Bought a trans/converter package deal from these guys because there stuff is supposed to be good. When we get the stuff it comes with a GM converter and no solenoid for the transbrake. So, they tell me to send the converter back and they will get me the correct one. They sent back the correct converter with a solenoid. We put everything together and then the transbrake doesn't work. Call them up and they tell me that maybe they sent me a trans without a brake. They tell me to pull it apart and send them the valve body back and they will send me a brake valve body. Do all of this and finally think everything is going good. 4 weeks at the track and the tranny won't shift into high gear. I drain the pan and it is full of metal shavings. Call Dynamic up and he tells me to put an in line filter on it that he thinks that there is probably something wrong with the pump. Said if filtering doesn't fix it to pull it out and have the tranny gone through.
Just wasn't a good experience to say the least!!!!!!!!!!
I've had a few from Joel and they all worked great.Joel did mine I had 2 Hughes that went down he redid the last one and no issues. I run a BBF (460) with a C4 behind it we have 120 or so passes with no issues
Joel's on Joy
(313) 581-6266
