1 - 4 of 4 Posts
i see some techs from mickey answer threads so...
there are two tubes that will fit a 15 x 12 rim with a 28 10.5 slick
which one will work better 3200 lbs car runs 8.40s normaly goes 1.23-1.28 sitxy but i hit a marginal track and it would spin if i hit it or shake it i pulled the power..tried new slicks and it still did it. i know the tubes should help even the mickey rep at the track busted my chops to put them in... so i am going to test it but really need to know which tube will work the best. i hope it is the litghter one ...
Brian,
You'll want to use our part number 9553. (yes, the lighter one :))
Let us know how you do with the tubes.
It wasn't Tommy busting your chops....was it????:p
Thanks,
Jaosn Moulton
i will let you and anybody who reads this what the outcome is...the only problem is trying to figure out a way to offset the weight:p
i did carbon fiber brakes and titanium center bolts.. when i put the beadlocks on..gona have to get tricky to offset 3.3 lbs each side..
thanks for the help
H&H Racing
thanks for the help
It must cost alot of money to build a front runner renegade car!!!
1 - 4 of 4 Posts
