1 - 6 of 6 Posts
I have a brand new 1250cfm acufab 4barral TB. Should I get a hat for it, or should I switch over to a 90mm with a nice elbow.
Accufab says their 90mm TB flows 1190 cfm. So based in just that you can make your decision. If it were me, I'd use the 4bbl style and buy a hat. 2 reasons. Cooler/you don't see them as often and
A hat is cheaper than a nice elbow.
Hat and 4 bbl. Bet it gives you more hood clearance too. Plus if it gets too small, don't the make a 1500+ cfm version?
Hat and 4 bbl gave me less hood clearance on my setup. But if he already has the 4 bbl throttle body and it'll fit with the hat, it's definitely not worth anything to switch to the elbow and 90 mm setup.
Custom Engine Shop
Get a hat you me even see better air distribution with the t/b & EV Carb Hat.
1 - 6 of 6 Posts
