1 - 4 of 4 Posts
starting to do the wiring again on the car. thinking about putting fuse block in for IC pump, fans, etc.
so, do you want the fuse block before the relay or between relay and fan, ic pump, etc
i was/am thinking about putting the fuse block between the relay and the item being powered. i figure that if there is going to be a short or issue, it would be from the item that is being powered shorting out?
ty
dean
1 - 4 of 4 Posts
